riceuguy | April 29, 2013
rodhoffman | April 29, 2013
tm | April 29, 2013
9 months, but it's much shorter now! That message is just a placeholder...call and ask when it will be ready!
Brian H | April 29, 2013
rchiang | April 29, 2013
tm | April 29, 2013
rchiang;
noel.smyth | April 29, 2013
inverts | April 29, 2013
txjak | April 29, 2013
noel;
considering how little kinetic energy the car has (comparatively) at 5 mph, that represents far less than 10% of normal stress/wear! I'd guess 40-50X less than the average stop. So maybe 1/10 the time, at 2.5% stress, or about ΒΌ of 1% wear!!
Noah.S | April 29, 2013
