Underbelly protection from salt
This is my single largest worry.
Living in the Northeast, we get outrageous amounts of salt dumped on our roads to go with the snow and ice. I don't want to watch the battery pack under the floor of the Model S corroded by salt water and destroyed. Does anyone know for a fact what Tesla is doing to protect the battery pack from the masses of ice, snow, water, gravel, and salt which will be thrown up against the bottom of the car in typical driving? I've been assuming that there will be some sort of solid, hard protection plate, but does anyone know for sure?
michiganmodels | April 25, 2011
@neroden
I believe that is a valid concern. However, I also believe Tesla has considered this (and other issues) because the battery pack sitting under the floor of the vehicle is the defining engineering benefit of the Model S. Watch the third video on the vehicle engineering blog (watch all three if you have a chance):
https://www.teslamotors.com/blog/tesla-vehicle-engineering
Straight Shooter | April 26, 2011
This is a big concern for me too. As a Canadain, I'll be driving my Model S Signature 12mths of the year. Salt is still the primary source of melting snow on our roads, especially in the Toronto area. This will be the ost expensive car I've purchased, so I don't want to see it eaten away.
You can imagine my distain if I have to go to ziebart and get the car sprayer with OIL to protect it from rust/corrosion.
Vawlkus | April 26, 2011
Thing you have to remember is that the bottom of the model s is not open, it's basically a solid sheet of carbon fibre, which isn't metal and won't rust. The battery is enclosed above that carbofibre sheet, so unless you rip the underside of your car off, your battery will never taste salt.
For those wondering how tough carbon fibre is, keep in mind that they made a tank out of carbon fibre as an experiment in weight reduction. It's not quite as tough as an abrahms tank, but it's not too far off that either.
Timo | April 26, 2011
Wasn't Models S frame based on aluminum, and not carbon fibre? If you have source for this info about car bottom being coated by carbon fibre, could you tell us, it would be great to see another engineering stuff about that car.
What I remember is that battery pack is swappable from bottom, connected to frame by few dozen screws, so no cover AFAIK. However material which that battery pack is made of is unknown to me.
Aluminum is very corrode-resistant, way better than steel because of natural oxide sheet that forms in surface of it. Salt water doesn't do squat to that (they make boats out of aluminum). However aluminum may corrode if it is touching or close to other metals by galvanic reaction. I just hope Tesla have taken that in consideration when designing the car (I see no reason why they haven't, but it is a new company which is boldly going where no man has gone before).
William13 | April 26, 2011
It should be more resistant to all forms of corrosion than other cars due to all aluminum except steel pillars and boron steel bumpers in the frame. There is a rumor that the battery pack may have additional protection from the road but no word as to what that would be. Though the battery pack composition has not been specified-- it felt and looked like metal. Thus I would assume it is also aluminum.
jfeister | April 26, 2011
Given that the battery needs to be encased in a non-metallic material to isolate ground, I don't see why it would react with salt. Only area of concern would be the connection points, similar to a normal car battery.
viao44 | April 27, 2011
Good question. Lots of snow and salty roads here.
Vawlkus | April 28, 2011
The frame is alum, and I thought the body panels were gonna be cf same as Roadster. Looking back on the old manufacturing blog, it's not cf at all, so my bad on that one.
I do know that the battery IS protected by a solid sheet of SOMETHING that it sits on, whatever the material is. It's that 'base plate' that allows for a rapid battery change.
William13 | April 28, 2011
The battery pack felt and looked like metal/aluminum at Detroit. Likely there is an insulator inside. A Tesla rep Indicated that the engineers were evaluating something to protect the bottom of the pack.
VolkerP | May 4, 2011
In the alpha prototype picture series, you can see that the battery pack has a welded metal casing. Manually welding aluminum is a hard job, so the alpha packs probably are made from steel.
Steel or aluminum, a metal casing needs some form of protection from galvanic corrosion, salt, and gravel.
Carbon fiber as encasing is not practical for mass production and as a shield is oversized (shield must not contribute to mechanical stiffness).
But we haven't heard any official statement from Tesla on that.
blaroux | May 4, 2011
Aluminum most definitely corrodes in salty environments... especially high strength aluminum. Only freshwater boats use aluminum hulls.
The Al2O3 passivation layer on aluminum holds up great to freshwater (unlike steel!) but the Cl- ions in salty water easily dissolve that layer. Aluminum actually corrodes faster than steel in those environments.
I worry more about the load-bearing components like suspension linkages than the battery. The alpha car did not seem to have any coatings on those aluminum extrusions. Looks like the bottom of the battery at least had something.
A hard anodize with polymer sealant would do an excellent job of protecting underbody aluminum.... hopefully they implement somthing like that in the final production model!
EdG | May 4, 2011
Is (structural) aluminum prone to cracking?
William13 | May 4, 2011
No concern about cracking of Aluminum. The Battery cases was definitly different color than plain aluminum. This might have represented anodized aluminum. Tesla has Welded aluminum structural frames in the alpha models- why not welded aluminum on the battery frame? I would say that looking at the pack in person, I saw nothing that looked like a welded seam. The structure had plenty of welded seams. I agree that my biggest concern for corrosion is the suspension-- no different than any other car.
Ad van der Meer | May 5, 2011
Audi is using aluminum for the A8 for some time now and I never heard the aluminum caused any problems.
qwk | May 5, 2011
Aluminum is way better than steel when it comes to corrosion. If you don't believe me, go look underneath a rust belt car. The body looks like a piece of cheese, while the trans/motor that are usually cast unpainted aluminum are affected very little.
jkirkebo | May 5, 2011
Aluminium is most definately used as a hull material in saltwater boats, there is plenty of aluminium boats here in Norway and they are kept in salt water at marinas the whole season.
For example, take a look at the Buster line, very popular.
http://www.buster.fi/en/mainpage
neroden | May 9, 2011
"I do know that the battery IS protected by a solid sheet of SOMETHING that it sits on, whatever the material is."
Well, that answers my #1 question. I hope it's a really corrosion-resistant material, but even if it isn't, I can examine the solid sheet for damage and get it repaired or patched (and indeed hose it off) well before any damage to the battery pack itself actually occurs.
"A Tesla rep Indicated that the engineers were evaluating something to protect the bottom of the pack."
...and this statement is what worries me. "Evaluating" something? They need something, something which is cheaper than a battery pack. If the one-piece surface of the battery pack gets damaged, I don't see any way to repair it, so it will just get progressively worse until it finally does damage the battery. If a separate sheet gets damaged, no need to replace the battery.
blaroux | May 9, 2011
should have specified - *bare* aluminum is not used in saltwater boat hulls.
Here is a decent article showing pictures of what happens to uncoated aluminum when exposed to de-icing salt: http://www.imoa.info/moly_uses/moly_grade_stainless_steels/architecture/...
"For example, there is a common misconception among architects that aluminum’s corrosion resistance is similar to that of stainless steel. This is incorrect. In locations that are exposed to chlorides (coastal or deicing salt), the corrosion rate of aluminum is typically 10 to 100 times that of stainless steel. The white to grayish white color of aluminum corrosion product may not bring attention to the problem (as the rusting red of steel does), until permanent aesthetic or structural damage has been done. This lack of knowledge makes aluminum a common replacement for stainless steel when construction costs must be reduced. Figures 4 and 5 show severe aluminum corrosion in a deicing salt laden environment and provide a significant contrast to Figure 2."
qwk | May 10, 2011
The point is that aluminum corrodes much less than steel. I don't see any stainless steel cars, do you?
Cars have a life expectancy, and are engineered to last a certaint amount of time. Tesla will be no different.
Timo | May 10, 2011
Also "steel" is not any element, it is a mixture of many materials, many of the aluminum alloys are also not pure aluminum, there are other things in them. There are differences between aluminum and aluminum :-P
kyawam | August 31, 2011
I think this is a valid concern. It's not the only concern, of placing the battery pack under the floor, here are some more.
1. All sort of Corrosion
2. Very high chances of being hit by gravel, stone and some hard and high speed bump.
3. flooding during raining season of some country
4. Bumpy roads in some countries
So I think Tesla really need to address waterproofing & impact protection for their motors and battery packs.
Jewsh | August 28, 2012
I too would really appreciate an update regarding galvanic corrosion. Is there isolation between the steel frame areas and the aluminum? Furthermore is there any anodization or paint on the aluminum exposed to the elements?
This car needs to last me at least 10 years or my wife will cut something near and dear to me off. (For the record, the Model S was her idea...)
Teoatawki | August 28, 2012
I can't speak about galvanic oxidation or isolation between steel and aluminum.
However, I have this tidbit about aluminum oxide from aluminumsulfate.net:
"Metallic aluminum is reactive with oxygen, which could cause corrosion to build up. However, when aluminum bonds with oxygen to form aluminum oxide, it creates a thin coating that protects it from oxidation. This keeps the aluminum from corroding and losing strength."
jerry3 | August 29, 2012
I never had a problem with the aluminium body and steel frame on the Land-Rover Series three (and I kept it for almost twenty years). I don't expect any problems with the Model S.
pilotSteve | August 29, 2012
These kind of design issues don't bother me. Tesla studies, designs, test, changes, and ultimately passes all the crash worthiness, fire safety, etc. standards with flying colors. I know from my previous engineering work on aerospace electronics there are many established standards that must also be met (FCC, UL, SAE, CE) that specifically include salt/corrosion, electromagnetic interference, shock/fire, etc.
I do not see any evidence that Tesla would skimp on these sorts of fundamental design issues and testing. Just because we would all like to see more blogs from the company describing what they've done so we can ohh and agh, yet its not forthcoming, is not reason to be concerned imo.
ICE requires corrosion warranties because the exhaust system, for example, lives its entire life with corrosive hot gasses and acidic fluid in contact. Not to mention ICE also has to deal with issues of dissimilar metals.
It IS something to talk about while we wait......
Brian H | August 29, 2012
pilot +1
Dr. Bob Reinke | January 9, 2013
Structural Aluminum definatly fails from salt corrosion. Check with anyone in the trucking industry. Lighter aluminum is desirable in the manufacture of semi-trailors.(inreases allowance of cargo weight) However, every year there are press storys of semi-trailor frames failing down under the weight of un-rigid loads such as loose cranberrys, watermellons, kernel-corn. Three to Five years are a long life for Aluminum frames under semis. Silicone and wax (Ziebart) sealing can extend the life of aluminum frames by several times.
lph | January 9, 2013
I don't know if you have taken a look at the bottom plate of the battery pack. It is about 1/4" thick!
It will take a long time for that to corrode through even if it were regular steel and aluminum is better in those situations. I don't know if it is anodized though. If it is, then there is almost no chance that there will be any issues. The bigger problem is as always the welds.
Brian H | January 9, 2013
The battery is enclosed in steel.
DTsea | January 9, 2013
I can tell you that aluminum- bare aluminum, machined- does not at ALL like salt exposure. Rinse it. Airplane fuselages use clad aluminum sheet for that reason (a 0.005" thick layer of pure aluminum is rolled with the sheet. 'Bare' to engineers means 'not clad.') The clad layer forms a tight aluminum oxide layer that is relatively corrosion resistant. Better than machined anyway. But if you drive in salt, rinse frequently. The owner's manual has a section on this.
The corrosion will also depend on the relative proximity of galvanic couples. For example, carbon fiber or titanium form a battery with aluminum in the presence of electrolyte. Salt water is a TERRIFIC electrolyte.
Presumably the carbon trim parts are well enough encapsulated to avoid forming the electric circuit with the aluminum body.
Steel- plain steel, or carbon steel, or alloy steel, corrodes easily in the presence of salt. Corrosion resistant steel (aka stainless) is better, but has mechanical properties inferior to the best alloy steels including those used in leaf springs.
LA-Thing | February 27, 2013
Saltwater has lower surface tension than fresh water, it penetrates into the smallest crevices and it’s not possible to flush it out with fresh water.
Even though the aluminium body, the encapsulated batteries and the suspension components will withstand the salty brine, what about cables, connectors, bolts and joints? Places where salt can hide or galvanic reactions can occur.
Is the Model S protected against corrosion from the factory? Are there any warranties on this similar to what most other car manufacturers have?
Is it recommended to treat the Model S with penetrating oil, wax based protecting media or similar?
Should treatment as described above be avoided in order not to create problems for batteries, cabeling, motor and inverter?
drp | February 27, 2013
LA
Have you asked these questions of Tesla? In the mean time I suggest you keep your car out of the ocean. They are great questions particularly for those of us who drive on salted roads several months a year. I just wash my car a few times a week.
Brian H | February 28, 2013
The battery body is not aluminum. It is steel, for body strength.
LA-Thing | May 4, 2013
Haven't got any good answers from Tesla, but have not been nagging.
The battery box being made from steel does not reduce my concerns. Steel does rust very well in the presence of salt.
What are the experiences made by the owners who have driven their cars through the first winter. Have anybody had a look on the underside of your car yet?
Ø | May 4, 2013
Norway calling, still having salty roads over here. Regarding salt, we prep our Cars with "Tectyl Dinol" and it works perfectly !
Ø | May 4, 2013
Here some instructions and how Tectyl Dinol works, 100% effective !!!
http://www.youtube.com/watch?v=toO83pULegE
Ø | May 4, 2013
For salty roads
http://www.dinol.com/
GeirT | May 5, 2013
Not at all a worry. Aluminium is less prone to oxidisation especially compared to steel and as is mentioned earlier in the thread, due to the forming of the aluminium oxide layer that is practically impenetrable. The Land Rover comparison is relevant. Also, don't forget the 8 year warranty on the battery.
Logic tells me that TM being the world leader in EV vehicles (!) will never risk reputation on something as basic as faulty battery packs, salt or no salt. Guaranteed, TM has considered this and taken necessary precautions for sure. Rose tinted spectacles? Perhaps, but have to have some belief in what I put my USD +100,000 into.
lolachampcar | May 5, 2013
Judging by the rest of the (over designed) suspension, I'd have to agree with GeirT.
rchiang | May 5, 2013
I assuming if the battery or plate is made out of aluminium after 10 to 15 years you probably have to replace the battery anyways. So I'm sure they will give you a new plate or better material that would be resistant. I don't think that salt will penatrate before that.
rdalcanto | May 5, 2013
I don't have 100% faith that they have thought about the salt that cars in other parts of the country are exposed to. Just look at the falcon doors on the Model X. Cool design, but not practical for people who live in places where it snows on the car frequently for 5 months or more each year. It seems like the designers forget that the cars will be driven beyond the Bay Area....
LA-Thing | May 11, 2013
Fastwalker; I'm in Norway too! Have spendt 1000's of NOK's on the products you mention to preserve my cars, unfortunately salt always wins the battle in the end.
In the meantime got answer from Tesla that the car is sufficiently protected against corrosion. They do however not have any specific warranty on this. Also, they do not recommend applying any aftermarket products to the car, i.e. don't put any Tectyl on the battery box.
So, we will just have to trust them that the salt will not bite. I just hope they have got some lessons learned from the cooperation with Mercedes. The E-class has been an expensive exercise for Mercedes in Norway, they have had to replace hundreds of doors, bonnets, wings etc.
Brian H | May 11, 2013
rchiang;
It's steel, for strength. Maybe coated.
Vawlkus | May 13, 2013
I THINK (do NOT know for fact) that the steel is internal structural components to the pack, and that the external paneling is all aluminum.
Brian H | May 13, 2013
The Nat Geo Factory tour showed the steel battery pack at about the 42 min. mark. Other statements made it clear, the steel pack is a major contributer to frame rigidity. Definitely steel.
Vawlkus | May 14, 2013
Doesn't mean that it's external Brian. There isn't one locally (yet) so I can't look for myself.
Brian H | May 14, 2013
It is the external case for the batteries. Showed clearly in the video.
vgrinshpun | May 14, 2013
@Brian H
I was told at a Tesla Store that battery casing is aluminum, but side beams are steel.
This was confirmed by an owner who tested various parts of the car under-body using a magnet:
http://www.teslamotorsclub.com/showthread.php/16650-Rust?p=336722&viewfu...
http://www.teslamotorsclub.com/showthread.php/16650-Rust/page2?p=336729&...
Regarding the Megafactories video, I think that the narrator talks about the battery pack frame, not casing.
Sudre_ | May 15, 2013
I just had a look at my S on the rack at the service center. It rubbed a bit in the middle a month ago and I figured while I was there they might as well look under it. There are two side beams and one middle that are steal skid plates basically. I did no damage to the aluminum battery case, just scratched the skid plates which is why they are there.
