Won't Charge: Can I borrow a cable for 5 minutes?
cprenzl | February 3, 2013
GoTeslaChicago | February 3, 2013
steven.addis | February 3, 2013
prash.saka | February 3, 2013
TINO F | February 3, 2013
jat | February 3, 2013
mrbry83 | February 3, 2013
