Anyone have an air leak around the sunroof?
This is not the creaking problem I have seen mentioned.
Under 60MPH the cabin is very quiet.
Over 60MPH there is a significant uptick in the air noise around the front of the sunroof when it is closed-- basically a hissing noise. I had the service center test drive it with me and they also concluded this was abnormal-- they have ordered a new front sunroof housing that will presumably fix this issue, which is suspected to be a loose seal.
Just wondering if anyone else has experienced this problem and how it was resolved.
Thanks.
gasnomo | March 17, 2013
My gasket pulled off as the delivery specialist showed me how tk use the sunroof for the first time. Still waiting on the replacement part.
jzahrt | March 17, 2013
I had a similar issue with almost the exact same symptoms. I could even see that the glass was not flush when closed. Tesla installed a new seal and it has been perfect ever since. I use it all the time, and the only issue I have now is the middle seat belt in the back whipping in the wind (very minor issue, but something I want to figure out sometime).
tesla-ss | March 18, 2013
I picked up my MS on Sunday and have driven it a few times on the freeway. Its a quiet cabin ride at slow speeds. But there is a clear uptick in the noise level from the center front area of the sunroof at speeds above 50mph. Need to to take it back to the service center..
chuck_wieland | March 18, 2013
I have the same issue driving into the wind and speeds over 70
ziggy | March 18, 2013
Yep, me to.. I will have to check the seal
Samtejwani | March 18, 2013
Thanks for the input.
Encouraged that jzahrt was able to get it resolved with a new seal.
I am taking it in to the service center next week, will repost with results.
mwojcie | March 18, 2013
Mine starts to make noise around 100mph - but I figured that was just the speed and to be expected.
pencil2man | April 1, 2013
curiously, my 1st high speed drive was up to about 100. the sunroof was quiet except that around 95 or so, there was a pop of sorts, then the sunroof has made wind noise at 70 ish above since. I did just notice that the thin black seal at the front of the roof varies in its height relative to the roof. will check with the service group about this.
