Removing warning labels on visors
I was wondering if anyone had removed, or tried removing the warning stickers on the underside of the front visors.
olanmills | 8 January, 2013
Don't try it!!!!
I tried it on my old car and I was encouraged when I partially peeled the corner off cleanly. I continued, and the rest did not go so well. A lot of the adhesive stayed behind, and there were also parts where the pulling stretched the liner and it parts of it were loose and seperated from the visor.
If you read about it online, you'll find out that this adhesives used for these labels are activated with heat, so they are pretty well stuck on to the visor. I have seen some advice that says you may be able to peel the label off using a heat gun, but this is risky because the heat may also cause the liner to seperate from the visor.
Also, examining the warning labels on the Model S, they look like they are adhered even more closely/tightly to the liner, almost like they're printed on. The labels show the dimpled texture of the liner fabric. On my old car, this was not the case.
Basically, I would not try it, but I feel your pain. I really hate those stupid labels. I don't need to see them every day for the rest of my life. I know what airbags are and what they do. I don't need this permanent label there uglifying my cars.
Brian H | 12 January, 2013
Overlay with little pin-ups?
Joyrider | 13 January, 2013
It has been decreed we ignorant consumers must see those labels so see those labels we shall.
olanmills | 15 January, 2013
@Brian H, you actually can by decals specifically to cover up the warning labels, but they're generally just as ugly and prominent. Some have graphics like flowers or flaming skulls or whatever, and there's other plain ones, but unless you're interior is exactly black, good luck trying to match the color and texture of the liner.
RobQ | 15 January, 2013
I haven't studied the S visor but on several of my cars I have been able to simply swap the right and left visor. This leaves the cursed attorneys sandwiched between the roof and visor unless they are down.
Brian H | 16 January, 2013
I was thinking more semi-nakedly ...
bp | 16 January, 2013
When lighted visors are available - won't they be a replacement for the current unlighted ones?
djp | 16 January, 2013
On my last car (Chrysler 300C SRT) I was able to get decals with just the SRT logo. Would be nice to get a decal with the "T" on it. It can be done with a little class.
marek.koenig | 24 June, 2013
This is extremely easy, I just got finished doing it. Take some isopropyl alcohol(91%) and damp a rag. Place that rag against the visor where the sticker is and hold it for 30 seconds. If you have a high quality rag then you can rub it a little bit as well.
Then the alcohol should start to loosen up the glue and it will start peeling away. With each application you should be able to remove about a quarter of the sticker. Took a few minutes, and now it's all gone.
GeekEV | 25 June, 2013
@marek.koenig - They must be using an alcohol based solvent in their adhesive. Cool. I might have to try that.
Wayne3 | 25 June, 2013
@marek.koenig - how clean is the resulting surface of the visor -- does all the glue come off with no residue? is there any discoloration between the outer border and the part that had the sticker? thanks
marek.koenig | 25 June, 2013
It came off perfectly clean, I can provide you with a picture if you want. Just don't have one with me.
no need for a pic -- your description is great; thanks
olanmills | 25 June, 2013
Dang. Now you made me look like a crazy old codger yelling to passersby.
Jken3 | 25 June, 2013
I would like to see a picture, if you please.
KirkP | 26 June, 2013
@marek.koenig - Do you have the alcantara or standard fabric headliner material on your visors?
GeekEV | 26 June, 2013
@KirkP - Ooh, good point. It might not come off as cleanly on the fabric...
RZitrin1 | 26 June, 2013
Geez, folks, I don't know....
It's kinda like removing the tags on pillows. VERY dangerous....
marek.koenig | 26 June, 2013
I have the standard stuff, driving a 40. Here is a picture: http://imgur.com/MJ4XOi0
Just try not to scrub, that may spread the color onto the fabric. Just press the damp cloth against the sticker and then peel.
michael1800 | 26 June, 2013
Thank you, Marek!
Mike C | 26 June, 2013
Anyone else get this to work? All I had was 70% - it didn't seem to do anything.
inverts | 26 June, 2013
Has anyone tried ethanol?
Looking forward to adding the visor warning to my mattress label collection ;-)
P.S. In a lab, we had a nice collection of warning labels, like "to avoid boil over, do not boil" and for extremely pure water (for DNA work) the MSDS noted that reactivity with water had not been assessed!
Wayne3 | 26 June, 2013
Here's the 91% stuff:
http://www.drugstore.com/walgreens-isopropyl-alcohol-first-aid-antisepti...
But has anyone tried this on the Alcantra visors? The label on these feels almost as soft as the rest of the visor, as though it's printed on the material directly. Is there really a separate label there?
Brian H | 27 June, 2013
There are a lot of people worried about their pillow labels. If they read them, they'd see "until delivered to the final consumer". Duh.
GeekEV | 27 June, 2013
This may also work (NOT TESTED) and it's upwards of 95% alcohol:
http://www.homedepot.com/p/Klean-Strip-Green-1-qt-Denatured-Alcohol-QKGA...
You can also get a 99% isopropyl alcohol, though I'm told they keep that behind the pharmacy counter so you have to ask for it.
jdb | 1 July, 2013
Can't believe that I just spent almost an hour of my life pealing off the Warning from driver's side visor. It never really bothered me. Must have been the challenge. Two problems. Used 70% isopropyl as that was what was handy. But main problem is that I'm a guy who over years has chewed his chunky fingernails to a nub. And this is a delicate fingernail job. After getting done, and it does look good, realized there is same Warning on other front visor. Duh. Will leave that for wife, she has fingernails. Will buy the 90% stuff for her to use, though she may think the entire project a waste of energy, and fingernails.
Brian10 | 7 July, 2013
@marek.koenig solution worked perfectly for me. I ordered 91% isopropyl and soaked a corner of a white rag. Then put the rag on the edge of the lable so the solution soaks into the visor and under the label. Once under the label, you can peal back the edge a little bit. I then soak this newly exposed area and keep slowly pealing. Got both labels off in about 25 minutes, totally worth it.
Brian H | 7 July, 2013
Brian10;
Did any cows return to the barn when you were slowly pealing?
|;p
jjs | 9 December, 2013
I have alcantara headliner/visors. I have owned the car for 11 months. Decided I would try the isopropyl alcohol (91%) and damp rag method above.
So for those of you that have alcantara and have owned your cars for a while here is what I found.
Time: 15-20 per visor
Results: Very good, not great. It looks better than with the labels on, but has left a mark/indentation where the labels were. Overall I'm glad I did it.
You might have better luck if you do it when the car is new. Then again you may not.
Just thought I would share for those of you who might be thinking of doing this.
gregguy | 9 December, 2013
Not sure this is the right point.
I need to clean a bit of ink from my headliner, any ideas.
nickjhowe | 9 December, 2013
Thanks @jjs. I keep thinking about doing it, but always chicken out.
Brian10 | 9 December, 2013
There is another thread on this same topic. The isopropyl alcohol(91%) did the trick for me. You have to be slow and patient but the label comes off and the visor looks perfectly fine afterwards.
Rheumboy | 9 December, 2013
So what do you do with the left over alcohol? 8-)
Captain_Zap | 9 December, 2013
Wow. Looking back at this thread it seems that we were pretty intense.
Brian H | 9 December, 2013
Warning labels! A philosophical take: a comic, showing a formally dressed Very Concerned Progressive Genetleman from the 1890s.
"I don't say kill all the stupid people! Just remove all warning labels, and let events take their course."
Pettifogger.ca.us | 2 March, 2014
The trick for me (besides using 91% isopropyl alcohol, cheap at Walgreens) was to start at the outside of the stickers and work in. The stickers are thin plastic and quite impervious to soaking themselves; you have to use the rag to soak the visor fabric at the edge of the sticker so that the alcohol gets under the sticker. It's then possible to laboriously remove the stickers, bit by bit, soak and repeat. The results on my alcantara visors look good, far better than with the stickers.
RUNS KWH | 25 August, 2014
I'm thinking about removing the ugly warning stickers as well. Just wanted to check and see if folks (recently) have been successful in doing so.
Pettifogger.ca.us | 25 August, 2014
You're not convinced by my March 2 success story? Gee, now me feelings is hurt.
Brian H | 25 August, 2014
Not recent enough!?
mclary | 25 August, 2014
Don't do it!!! You will void the warranty!
Brian H | 26 August, 2014
Warranty on the visors is very limited.
RUNS KWH | 27 August, 2014
Does the visor stain at all, with the alcohol mix?
Brian10 | 27 August, 2014
There is an earlier, very long thread on this but I, also, followed the same method as the others, used 91% rubbing alcohol, took my time and it pealed right off, no stains, looks fantastic.
bobrobert | 29 August, 2014
Thanx - sort of. I used the 91% and it did remove the labels, but left a slightly yellow shadow, only noticeable in strong light (standard interior.) Still, I prefer that to the labels.
Alex K | 29 August, 2014
I did the label removal too. More info and pictures a http://www.teslamotorsclub.com/showthread.php/35176-Removing-warning-fro...
