Blake
bfranks273 | 26 February, 2013
Wow, dont have all the inter-day details , just went on a quick trip and left her outside unplugged in the DC area Fri morning to Tues morning . Roughly 45 to 25 degrees F daily. Ideal went 261 to 195 . It is worse than I saw in the fall so cold does have an add'l effect. V4.2.
Brian H | 26 February, 2013
Probably, it's partly because the car doesn't know when you're going to want it again, and keeps the battery from dropping all the way to ambient outdoor temperature. When timing is available, you can let it drop all the way down; cold itself is not harmful, and will not reduce range. Charging and driving when cold is harmful, though, so allow enough time to pre-warm (preferably on "shore power") after a long "cold soak".
Actually, after any length of "cold soak" it should be pre-warmed if possible. Starting out immediately when cold will cause the car to dump huge current into the battery heating system for a while.
AndresL | 7 March, 2013
@Nick - Excellent post, thank you! I live in the same area and experienced the same issues these past 2 weeks with the temperature drops, losing as much as 14 miles a night (7 PM to 7 AM) when the temperatures reached the low 50s. I was also concerned and wondering about the losses, which definitely distort what Tesla promotes in terms of idle discharge rates, monetary savings and the general range of the car (when taking into account separate short trips over a period of weeks rather than a single long trip). I hope they come out with the next firmware version soon, and that it addresses the sleep mode and any other charge loss issues. I would certainly suggest to enable smart sleep modes, in which they allow most components to go into sleep mode but perhaps the vital ones necessary for a fast start-and-go to remain more "alert" for needs. Also a programmable timer on sleep mode would most probably take care of 90% of the problems, as most of us can easily predict 90% or more of our cars' idle times.
nickjhowe | 7 March, 2013
At the Tesla Oslo event last night Elon said Tesla currently expects cars to lose 2-3% battery capacity each night (seems too optimistic based on our experience), and this will drop to 0.2% when they re-enable sleep mode.
Brian H | 7 March, 2013
At the Oslo event, Elon said sleep would return before shipments to Europe began in July.
bobinfla | 8 March, 2013
@Nick: Very excellent and timely post. I'll be parking my car for 7 1/2 days at Orlando Airport next week and this was exactly the real world data I came looking for today. Thanks.
Jolinar | 8 March, 2013
@nickjhowe
If I read it correctly, your car lost 58 miles in 6.5 days. That means 8.9miles/day => battery would be empty (from full 265 to 0) in 29 days. That is parasitic load of 3.36% per day. More than Elon stated in Oslo (2-3%), but not that much more :-)
However I agree, sleep mode is needed.
nickjhowe | 8 March, 2013
@Jolinar - I wonder how long that same drop would continue, and whether it would go down to zero. At some point the car goes into battery save mode. But I don't know when that would happen.
mw | 8 March, 2013
98% of the time I plug my car in at night. On the few occasions I left it unplugged overnight, it lost about 10 miles of range in 30 F temps. I'm in Ohio. I have noticed on really cold days 12 F while parked at work I would get home with 150ish miles of range out of the 230 I had in the morning. That is a 42 mile round trip. 50% highway. So some was warming the battery after i started driving and some was loss while sitting. The android app wasn't released until after our cold snap so I wasn't able to pre warm the car. In the really cold temps my wh/mi were around 550 and in 45 F or greater I use about 300 to 350 wh/mi... depending on how heavy my foot is on the highway :) Usually drive 80. I have found that 45 F seems to be the tipping point for using more energy to warm the battery... at least that is when I notice the wh/mi going up.
dortor | 8 March, 2013
Going to bed tonight with 250 miles range - will update status in morning - expect low 40s over night - first time over night
dortor | 9 March, 2013
250 miles rated range @ 10 pm
241 miles rated range @ 7:33 am
Low temp over night 33 F...
That's my one data point
Peter7 | 9 March, 2013
All,
It looks like a lot of the confusion here is being created by using the "Rated Miles" number as the amount of energy left in the battery. This number is a computer generated number based on a number of things, mainly temperatures. We should instead be looking at the battery level. This is shown both on the dash, the app, and (most easy to read) the big 17" screen. If you watch that, you will see that during these cold soaks that cause the "Rated Range" to drop, the battery percentage has not moved my any more than expected due to the lack of sleep mode.
For example if you go to Nickjhowe great graphic, you can see that the battery percentages for each day are about: 74%, 72%, 68%, 65%, 62%, 59%, which fits with the range displayed also as the car was kept at about the same temperature the whole time.
Peter
DouglasR | 9 March, 2013
@Peter7
Where do you see battery percentage on the dash, app, and touch screen? I must be missing it.
Peter7 | 10 March, 2013
They unfortunately don't display the number on the screen, though you can snag it from the API if you mess with that stuff. But you can see the 10% marks on the battery displays, the rest is rough estimation. It's not perfect, but it does work.
Peter
prash.saka | 10 March, 2013
For mine, the drop is closer to 1 mile per hour. I left mine in the garage at around 40 degrees for two nights and a day and the drop was over 30 miles, from 157 to 124.
Even now, when I left it outside where the temperature is over 40 degrees, the drop is 1 mile per hour, from 55 to 51 in 4 hours.
I can't charge it every night as the apartment complex isn't letting me use any power outlets. And I desperately need the sleep mode. Is there a way to rollback the software version, from 4.2 to 4.1, for just the sleep mode?
~ Prash.
DouglasR | 10 March, 2013
@Peter -- I don't see 10% marks on the app. They might be on the displays; next time I get in the car I'll put my glasses on to look. I never noticed them before.
Brian H | 10 March, 2013
@Peter;
OT, did you see the "Buddy Box" that was referred to elsewhere?
http://elecordset.com/moreinfo.aspx?pid=QSBB-50&cs=/products/rv-accessor...
How does that relate to you MI-EVSE?
typo: to your MI-EVSE
Damian | 10 March, 2013
While this is not mine, I agree and think it bears repeating:
"I'm an engineer and am able to estimate range/conditions/etc (and enjoy it!), but to be really mainstream, I think Tesla can/should do more to help drivers manage their driving - they have not been really clear/open about parking- and temperature-related losses and the on-board tools and the app don't really help you estimate where you really stand. For example, they could integrate Nav, Weather and Energy apps and really give you a trip planner that takes a lot more into account. Right now, for example, I have to consider speed, route (climbs) and real-world consumption to plan a trip. For example, while you might have enough total energy to get home based on average consumption, if there is a big climb shortly before you get there you can still run out before the top! As more non-tech and non-early-adopter types buy, it will be too easy for them to mis-estimate and get stuck with the current tools."
There is one thing I am not clear about. I hear folks are charging in the cold and it seems as if they are not stopping at 80% but are allowing the battery to be charged all the way to 100%. I believe I saw recommendations to charge only to 80% since 100% will diminish the battery's capacity over the 8 year length of the battery pack. Has anyone else received this instruction?
Brian H | 11 March, 2013
It seems to make a difference if you start driving right away. Sitting at 100% is the real problem.
ChristianG | 11 March, 2013
@Damian,if I understood it right, they don't really charge up to 100% they put it on Range mode but don't allow it to lead fast, that way the battery pack will be heated when they leave shortly afterwards.
This is just a way to force the car to pre heat the pack. I don't know if that's still necessary with the app.
Peter7 | 1 April, 2013
Hey BrianH,
Unfortunately it looks like the "Buddy Box" won't help. It still draws from a single 14-50, which is limited to 50A (40A continuous). My MI-EVSE needs two 50A supplies to merge to supply the 80A to the car.
Peter
RedShift | 1 April, 2013
My car was at service last week. They charged to max range and let it sit in the lot.
When I asked about it, they said if you do max range once or twice a week it's fine.
I am not so sure though.
JayBoy | 2 April, 2013
Peter,
Is your MI-EVSE being sold?
Jay
Divesh | 27 April, 2013
I just started driving my Model S for the past 1 week. I travel everyweened from Yuma, AZ to San Diego, CA which is 185 miles. Yesterday was the first I drove this on Tesla. When I left Yuma I had 270 miles(standard mode charge) traveled at 67miles/hr(cruise cotnrol) when I reached San Deigo, was left with 28miles. Interior temp was 73 F.
I charged it in San Diego to 300 miles Max charge and parked in garage and within 8hours it has discharged to 265miles.
lost 35 miles in just under 8 hours.
Thom EM | 7 January, 2014
@Damian: good eye on that engineering take. The basic problem is equating battery charge energy to "miles of range" when there are other demands on the energy, notably for environmental control, computer connectivity, hill climbing and the rest. My suggestion to Tesla:
* Allow us to put the main speedo display in energy units (as the switch advertises but doesn't deliver)
* Give us projected range (from the energy app) on the main speedo display of the energy app.
* Once that is done, follow the ideas below for integrating weather, Nav speed, topography, lodging and charger placements, with the energy app into an onboard trip planner like PlugShare, but better.
crazybrit | 7 January, 2014
+1 @ThosEM and @Damian
Pages
